Dell Precision 7560 Screen Replacement
  1. Dell Precision 7560 Screen Replacement, Screen: step 1, image 1 of 3 Dell Precision 7560 Screen Replacement, Screen: step 1, image 2 of 3 Dell Precision 7560 Screen Replacement, Screen: step 1, image 3 of 3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: step 2, image 1 of 2 Dell Precision 7560 Screen Replacement: step 2, image 2 of 2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: step 3, image 1 of 3 Dell Precision 7560 Screen Replacement: step 3, image 2 of 3 Dell Precision 7560 Screen Replacement: step 3, image 3 of 3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Laisha
205 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 57
All Time: 1,655
