Dell Precision M2400 Memory Module Replacement
  1. Dell Precision M2400 Memory Module Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latches toward each other to lock them in an open position.
    • Slide the battery out of the battery bay.
  2. Dell Precision M2400 Memory Module Replacement, Base Cover: step 2, image 1 of 1
    • Loosen the captive screw.
    • Slide the bottom of the base assembly away from the hinge covers, and lift to remove the bottom of the base assembly.
  3. Dell Precision M2400 Memory Module Replacement, Memory Module: step 3, image 1 of 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Johnathan Hammond
45,237 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 107
