Dell Precision M3800 Fan Replacement
  1. Dell Precision M3800 Fan Replacement, Back Cover: step 1, image 1 of 2 Dell Precision M3800 Fan Replacement, Back Cover: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Fan Replacement: step 2, image 1 of 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Fan Replacement, Fan: step 3, image 1 of 2 Dell Precision M3800 Fan Replacement, Fan: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
  4. Dell Precision M3800 Fan Replacement: step 4, image 1 of 3 Dell Precision M3800 Fan Replacement: step 4, image 2 of 3 Dell Precision M3800 Fan Replacement: step 4, image 3 of 3
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
  5. Dell Precision M3800 Fan Replacement: step 5, image 1 of 2 Dell Precision M3800 Fan Replacement: step 5, image 2 of 2
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,607
