Dell Precision M3800 RAM (Memory) Replacement
  1. Dell Precision M3800 RAM (Memory) Replacement, Back Cover: step 1, image 1 of 2 Dell Precision M3800 RAM (Memory) Replacement, Back Cover: step 1, image 2 of 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 RAM (Memory) Replacement: step 2, image 1 of 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 RAM (Memory) Replacement, Battery: step 3, image 1 of 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): step 4, image 1 of 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): step 4, image 2 of 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): step 4, image 3 of 3
    • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
    • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 20
All Time: 596
