Dell Precision M4400 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond and one other contributor
Last updated on November 10, 2019
7 - 15 minutes
Easy
Community-Contributed Guide
Tools
  1. Dell Precision M4400 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
  2. Dell Precision M4400 Hard Drive Replacement, Base Cover: step 2, image 1 of 1
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
  3. Dell Precision M4400 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Precision M4400 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging.
    • Remove the four M3 x 3-mm screws securing the hard drive. These screws are on the bottom of the base cover.
    • NOTE: If the bottom of the base cover is detached from the laptop, the four screws securing the hard drive are marked with an "H".
    • Slide the hard drive out of the computer.
    • Remove the face plate screw and then the face plate from the hard drive.
Johnathan Hammond
45,189 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,224
