Dell Precision M4600 Memory Module Replacement
  1. Dell Precision M4600 Memory Module Replacement, Battery: step 1, image 1 of 2 Dell Precision M4600 Memory Module Replacement, Battery: step 1, image 2 of 2
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
  2. Dell Precision M4600 Memory Module Replacement, Base Cover: step 2, image 1 of 3 Dell Precision M4600 Memory Module Replacement, Base Cover: step 2, image 2 of 3 Dell Precision M4600 Memory Module Replacement, Base Cover: step 2, image 3 of 3
    • Remove the screws that secure the base cover to the computer.
    • Press the rubber feet towards the rear of the system to disengage the bottom door.
    • Remove the base cover from the computer.
  3. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: step 3, image 1 of 3 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: step 3, image 2 of 3 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: step 3, image 3 of 3
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
  4. Dell Precision M4600 Memory Module Replacement, KeyBoard: step 4, image 1 of 3 Dell Precision M4600 Memory Module Replacement, KeyBoard: step 4, image 2 of 3 Dell Precision M4600 Memory Module Replacement, KeyBoard: step 4, image 3 of 3
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
  5. Dell Precision M4600 Memory Module Replacement: step 5, image 1 of 3 Dell Precision M4600 Memory Module Replacement: step 5, image 2 of 3 Dell Precision M4600 Memory Module Replacement: step 5, image 3 of 3
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
  6. Dell Precision M4600 Memory Module Replacement: step 6, image 1 of 1
    • Peel the keyboard data cable away from the keyboard and remove.
  7. Dell Precision M4600 Memory Module Replacement, Memory Module: step 7, image 1 of 2 Dell Precision M4600 Memory Module Replacement, Memory Module: step 7, image 2 of 2
    • Flip the the Bottom
    • Gently pry the retention clips away from the memory modules.
    • Remove the memory modules from the computer.
  8. Dell Precision M4600 Memory Module Replacement: step 8, image 1 of 2 Dell Precision M4600 Memory Module Replacement: step 8, image 2 of 2
    • Flip to the Top.
    • Gently pry the retention clips away from the memory module.
    • Remove the memory module from the computer.
Johnathan Hammond
45,582 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
44 Members
1,996 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,474
