Dell Precision M4700 CPU Replacement
  1. Dell Precision M4700 CPU Replacement, Optical Drive: step 1, image 1 of 1
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700 CPU Replacement: step 2, image 1 of 2 Dell Precision M4700 CPU Replacement: step 2, image 2 of 2
    • Remove the two 3mm screws that secure the base cover to the computer with a Phillips #00 screwdriver.
    • Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700 CPU Replacement: step 3, image 1 of 2 Dell Precision M4700 CPU Replacement: step 3, image 2 of 2
    • Remove the 3mm screw that secures the optical drive to the computer with a Phillips #00 screwdriver.
    • Slide the optical drive out.
  4. Dell Precision M4700 CPU Replacement, CPU: step 4, image 1 of 2 Dell Precision M4700 CPU Replacement, CPU: step 4, image 2 of 2
    • Pry up the keyboard trim starting from the top-inner edge with a plastic opening tool or spudger.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge with a plastic opening tool or spudger.
  5. Dell Precision M4700 CPU Replacement: step 5, image 1 of 3 Dell Precision M4700 CPU Replacement: step 5, image 2 of 3 Dell Precision M4700 CPU Replacement: step 5, image 3 of 3
    • Remove the four 3mm screws that secure the keyboard to the computer with a Phillips #00 screwdriver.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board by flipping up the locking tab of the ZIF connector and gently pulling out the cable.
    • Remove the keyboard.
  6. Dell Precision M4700 CPU Replacement: step 6, image 1 of 2 Dell Precision M4700 CPU Replacement: step 6, image 2 of 2
    • Remove four 5mm screws that secure the hard drive to the computer with a Phillips #00 screwdriver.
    • Unscrew the 3mm Phillips #00 locking screw. Slide the release latch to unlock the hard drive.
    • Slide the hard drive out from the computer.
  7. Dell Precision M4700 CPU Replacement: step 7, image 1 of 3 Dell Precision M4700 CPU Replacement: step 7, image 2 of 3 Dell Precision M4700 CPU Replacement: step 7, image 3 of 3
    • Remove the five 3mm Phillips #00 screws that secure the lower palm rest to the bottom of the laptop.
    • Remove the twelve 5mm Phillips #00 screws that secure the upper palm rest to the keyboard side of the laptop.
  8. Dell Precision M4700 CPU Replacement: step 8, image 1 of 3 Dell Precision M4700 CPU Replacement: step 8, image 2 of 3 Dell Precision M4700 CPU Replacement: step 8, image 3 of 3
    • Disconnect the ribbon cables that connect the palmrest to the bottom of the device.
    • Pull on the tabs to disconnect the two wider connections.
  9. Dell Precision M4700 CPU Replacement: step 9, image 1 of 2 Dell Precision M4700 CPU Replacement: step 9, image 2 of 2
    • Pry up between the palmrest and case with a plastic opening tool, starting on the left side.
    • Work around the side farthest from the screen prying the palmrest up.
  10. Dell Precision M4700 CPU Replacement: step 10, image 1 of 2 Dell Precision M4700 CPU Replacement: step 10, image 2 of 2
    • Remove the two 5mm screws connecting the fan to the device with a Phillips #00 screwdriver.
    • Disconnect the wires connecting the fan to the motherboard.
  11. Dell Precision M4700 CPU Replacement: step 11, image 1 of 2 Dell Precision M4700 CPU Replacement: step 11, image 2 of 2
    • Unscrew the four captive screws with a Phillips #00 screwdriver.
    • Pull the CPU heatsink out. To remove it, grab the heatsink and pull it out and upward.
    • Captive screws should not be able to be removed. They only screw, they do not come out.
    • Be sure to clean both contact points on the CPU and heatsink with isopropyl alcohol and reapply fresh thermal paste before reinstalling the heatsink.
  12. Dell Precision M4700 CPU Replacement: step 12, image 1 of 2 Dell Precision M4700 CPU Replacement: step 12, image 2 of 2
    • Unlock the CPU by using flathead screwdriver on the circular lock and turning.
    • Using two fingers, grab the CPU and lift it directly upwards from the motherboard gently.
    • Once it is unlocked, it will come out very easily so do not use excessive force and be sure to avoid bending any of the pins located on the underside.
3 other people completed this guide.
Dylan
385 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 36
All Time: 2,494
