Dell Precision M4700 RAM Replacement
  1. Dell Precision M4700 RAM Replacement, RAM: step 1, image 1 of 3 Dell Precision M4700 RAM Replacement, RAM: step 1, image 2 of 3 Dell Precision M4700 RAM Replacement, RAM: step 1, image 3 of 3
    • Unplug the charging cable before disassembly to avoid electric shocks.
    • Shut down the laptop.
    • Slide the battery eject button to the right until the battery lifts.
    • Carefully remove the battery from the laptop.
  2. Dell Precision M4700 RAM Replacement: step 2, image 1 of 3 Dell Precision M4700 RAM Replacement: step 2, image 2 of 3 Dell Precision M4700 RAM Replacement: step 2, image 3 of 3
    • Remove two 5 mm screws using a Phillips #0 screwdriver.
  3. Dell Precision M4700 RAM Replacement: step 3, image 1 of 2 Dell Precision M4700 RAM Replacement: step 3, image 2 of 2
    • Slide the back panel upwards.
    • Lift the panel out of the way to access the RAM bay.
  4. Dell Precision M4700 RAM Replacement: step 4, image 1 of 2 Dell Precision M4700 RAM Replacement: step 4, image 2 of 2
    • Use your fingers to push the metal retaining clips in opposite directions.
    • The RAM will pop up.
    • Remove the RAM from its slot.
  5. Dell Precision M4700 RAM Replacement: step 5, image 1 of 2 Dell Precision M4700 RAM Replacement: step 5, image 2 of 2
    • If you have purchased more than one RAM chipset, repeat Step 4 for the right side of the RAM bay.
2 other people completed this guide.
dvalencia
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 315
