Dell Precision M6600 Hard Drive Replacement
Kaley lindsay
Kaley lindsay and 3 other contributors
Last updated on November 15, 2022
10 minutes
Moderate
Needs More Images
Better Introduction
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Dell Precision M6600 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: step 2, image 1 of 2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: step 2, image 2 of 2
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: step 3, image 1 of 2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: step 3, image 2 of 2
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: step 4, image 1 of 1
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
4 other people completed this guide.
Kaley lindsay
582 Reputation
4 Guides authored
One Comment
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 26
All Time: 3,915
