Dell Precision M6800 Keyboard Replacement
  1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: step 1, image 1 of 1
    • Replacing Dell Precision M6800's keyboard
  2. Dell Precision M6800 Keyboard Replacement: step 2, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 2, image 2 of 2
    • Before any repair, you should remove battery
  3. Dell Precision M6800 Keyboard Replacement: step 3, image 1 of 1
    • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
  4. Dell Precision M6800 Keyboard Replacement: step 4, image 1 of 1
    • Unscrew 4 fastening screws which are at bottom of keyboard
  5. Dell Precision M6800 Keyboard Replacement: step 5, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 5, image 2 of 2
    • Pry out four hooks which are on the sides of keyboard (two per one site)
    • Be carefull to not break of hooks - use constant force and do it slowly
  6. Dell Precision M6800 Keyboard Replacement: step 6, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 6, image 2 of 2
    • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
    • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
  7. Dell Precision M6800 Keyboard Replacement: step 7, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 7, image 2 of 2
    • Pry up the white part of connector (constant for both sides) and eject connecting flex
5 other people completed this guide.
Szymon Milewski
831 Reputation
3 Guides authored
2 Guide Comments
Great job, thank you
kali1902 - Reply
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 48
All Time: 1,875
