Dell Streak 7 GSM Module Replacement
  1. Dell Streak 7 GSM Module Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 GSM Module Replacement: step 2, image 1 of 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 GSM Module Replacement: step 3, image 1 of 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 GSM Module Replacement: step 4, image 1 of 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 GSM Module Replacement: step 5, image 1 of 2 Dell Streak 7 GSM Module Replacement: step 5, image 2 of 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 GSM Module Replacement: step 6, image 1 of 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 GSM Module Replacement: step 7, image 1 of 2 Dell Streak 7 GSM Module Replacement: step 7, image 2 of 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 GSM Module Replacement, GSM Module: step 8, image 1 of 2 Dell Streak 7 GSM Module Replacement, GSM Module: step 8, image 2 of 2
    • With the spudger, disconnect the antenna cable located on the module.
  9. Dell Streak 7 GSM Module Replacement: step 9, image 1 of 2 Dell Streak 7 GSM Module Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the tape connected to the GSM module.
  10. Dell Streak 7 GSM Module Replacement: step 10, image 1 of 2 Dell Streak 7 GSM Module Replacement: step 10, image 2 of 2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  11. Dell Streak 7 GSM Module Replacement: step 11, image 1 of 1
    • Disconnect the GSM module by lifting the module up, out of the case.
Ali Benjelloun
376 Reputation
3 Guides authored
USF Tampa, Team 4-6, Passmore Fall 2016 Member of USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 259
