Introduction
Here we'll cover how to remove the bottom hatch of the laptop, how to remove the drive caddy, and how to remove the actual hard drive. .
Gather tools and materials
Flip over laptop, and remove battery as a safety precaution
If you look at the bottom of the laptop, you will notice that there is a panel that is removable
Unscrew the screws that hold the panel in place
Unscrew the screws until they are loose. They will not come out of the panel
After loosening all the screws, lift the panel up from the main chassis
You may need to use a flathead screwdriver to lift the panel
Tool used on this step:Tweezers$4.99
Now we have access to the internals of the laptop, pretty neat
If the battery is away from you, the hard drive should be closer towards you on the left
Start by removing the screws holding the caddy into the chassis
These screws have a more rounded top, and are longer
Once loosened, you can remove with your fingers or tweezers, and then set them aside
Now we remove the screws holding the drive to the caddy
These screws are have a flatter head, and are shorter
These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
The manufacturer likes to put these in very tightly, and it may take some effort to remove. I suggest using a screwdriver with a bigger handle, not the one I am using
Set these screws aside, apart from the screws we removed in the last step
If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
Pull this tab gently in order to remove the cable
Again, wiggling also helps
If you removed the drive using steps 1-7 then what you have should be left in picture 1
If you had trouble removing the drive, and you went through to step 8, then the parts remaining will be in picture 2
The drive should have a SATA interface, so you should be able to mount it into another computer using 2.5" to 3.5" converter brackets and a SATA cable
13 other people completed this guide.
