Dell Studio 1555 Display Replacement
  1. Dell Studio 1555 Display Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Display Replacement: step 2, image 1 of 3 Dell Studio 1555 Display Replacement: step 2, image 2 of 3 Dell Studio 1555 Display Replacement: step 2, image 3 of 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Display Replacement: step 3, image 1 of 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Display Replacement, Display: step 4, image 1 of 2 Dell Studio 1555 Display Replacement, Display: step 4, image 2 of 2
    • Insert a plastic opening tool between the bezel and the display cover.
    • Wiggle it to the release the latches.
    • Separate the bezel from the cover.
  5. Dell Studio 1555 Display Replacement: step 5, image 1 of 2 Dell Studio 1555 Display Replacement: step 5, image 2 of 2
    • Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
  6. Dell Studio 1555 Display Replacement: step 6, image 1 of 1
    • Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
    • Unplug the camera cable.
  7. Dell Studio 1555 Display Replacement: step 7, image 1 of 2 Dell Studio 1555 Display Replacement: step 7, image 2 of 2
    • Place the LCD face down on the top cover.
    • Remove the sticky tape securing the video cable connector.
    • Unplug the video cable from the screen.
  8. Dell Studio 1555 Display Replacement: step 8, image 1 of 3 Dell Studio 1555 Display Replacement: step 8, image 2 of 3 Dell Studio 1555 Display Replacement: step 8, image 3 of 3
    • Remove the LCD from the laptop.
    • Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
    • You will have to transfer the mounting brackets to the new screen.
3 other people completed this guide.
Josh Boone
586 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,743
