Dell Studio 1555 Keyboard Replacement
  1. Dell Studio 1555 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Keyboard Replacement: step 2, image 1 of 3 Dell Studio 1555 Keyboard Replacement: step 2, image 2 of 3 Dell Studio 1555 Keyboard Replacement: step 2, image 3 of 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Keyboard Replacement: step 3, image 1 of 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
  5. Dell Studio 1555 Keyboard Replacement: step 5, image 1 of 2 Dell Studio 1555 Keyboard Replacement: step 5, image 2 of 2
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
  6. Dell Studio 1555 Keyboard Replacement: step 6, image 1 of 2 Dell Studio 1555 Keyboard Replacement: step 6, image 2 of 2
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
  7. Dell Studio 1555 Keyboard Replacement: step 7, image 1 of 1
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
  8. Dell Studio 1555 Keyboard Replacement: step 8, image 1 of 3 Dell Studio 1555 Keyboard Replacement: step 8, image 2 of 3 Dell Studio 1555 Keyboard Replacement: step 8, image 3 of 3
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
  9. Dell Studio 1555 Keyboard Replacement: step 9, image 1 of 1
    • Remove the keyboard
2 other people completed this guide.
Hunter Tuck
214 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 926
