Dell Studio 1737 Keyboard Replacement
  1. Dell Studio 1737 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Studio 1737 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: step 3, image 1 of 1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: step 4, image 1 of 3 Dell Studio 1737 Keyboard Replacement: step 4, image 2 of 3 Dell Studio 1737 Keyboard Replacement: step 4, image 3 of 3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: step 5, image 1 of 1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: step 6, image 1 of 2 Dell Studio 1737 Keyboard Replacement: step 6, image 2 of 2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: step 7, image 1 of 2 Dell Studio 1737 Keyboard Replacement: step 7, image 2 of 2
    • Remove the ribbon cable as shown
2 other people completed this guide.
Joseph Jacavone
785 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 824
