Dell VRP100 Camera Replacement
  1. Dell VRP100 Camera Replacement, Cover Panel: step 1, image 1 of 3 Dell VRP100 Camera Replacement, Cover Panel: step 1, image 2 of 3 Dell VRP100 Camera Replacement, Cover Panel: step 1, image 3 of 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Camera Replacement: step 2, image 1 of 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Camera Replacement: step 3, image 1 of 3 Dell VRP100 Camera Replacement: step 3, image 2 of 3 Dell VRP100 Camera Replacement: step 3, image 3 of 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Camera Replacement: step 4, image 1 of 3 Dell VRP100 Camera Replacement: step 4, image 2 of 3 Dell VRP100 Camera Replacement: step 4, image 3 of 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Camera Replacement, Camera: step 5, image 1 of 3 Dell VRP100 Camera Replacement, Camera: step 5, image 2 of 3 Dell VRP100 Camera Replacement, Camera: step 5, image 3 of 3
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  6. Dell VRP100 Camera Replacement: step 6, image 1 of 2 Dell VRP100 Camera Replacement: step 6, image 2 of 2
    • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
    • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
  7. Dell VRP100 Camera Replacement: step 7, image 1 of 2 Dell VRP100 Camera Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the flat-topped connector by lifting it straight up from the motherboard.
    • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
    • To reinstall, line up the connectors and firmly push until you hear a pop.
Lauren Monzon
235 Reputation
2 Guides authored
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 535
