Dell Venue 11 Pro Keyboard Port Replacement
  1. Dell Venue 11 Pro Keyboard Port Replacement, Battery: step 1, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement, Battery: step 1, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement, Battery: step 1, image 3 of 3
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro Keyboard Port Replacement: step 2, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 2, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 2, image 3 of 3
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro Keyboard Port Replacement, Frame: step 3, image 1 of 2 Dell Venue 11 Pro Keyboard Port Replacement, Frame: step 3, image 2 of 2
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro Keyboard Port Replacement: step 4, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 4, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 4, image 3 of 3
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro Keyboard Port Replacement: step 5, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 5, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 5, image 3 of 3
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro Keyboard Port Replacement: step 6, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 6, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 6, image 3 of 3
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro Keyboard Port Replacement: step 7, image 1 of 1
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro Keyboard Port Replacement: step 8, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 8, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 8, image 3 of 3
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro Keyboard Port Replacement: step 9, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 9, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement: step 9, image 3 of 3
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
  10. Dell Venue 11 Pro Keyboard Port Replacement, Keyboard Port: step 10, image 1 of 3 Dell Venue 11 Pro Keyboard Port Replacement, Keyboard Port: step 10, image 2 of 3 Dell Venue 11 Pro Keyboard Port Replacement, Keyboard Port: step 10, image 3 of 3
    • Next, you need to remove the two ribbon cables located at the bottom of the frame. To detach the first ribbon cable you need to pull straight up on the orange connecter.
  11. Dell Venue 11 Pro Keyboard Port Replacement: step 11, image 1 of 2 Dell Venue 11 Pro Keyboard Port Replacement: step 11, image 2 of 2
    • To remove the second ribbon cable you must first raise a black retainer with a thin plastic tool. Then you must pull the cable down to free it from the frame.
  12. Dell Venue 11 Pro Keyboard Port Replacement: step 12, image 1 of 2 Dell Venue 11 Pro Keyboard Port Replacement: step 12, image 2 of 2
    • Now you must remove two 2.5mm screws that are securing the keyboard port to the frame. When removing the screws use the Phillips #000 bit.
  13. Dell Venue 11 Pro Keyboard Port Replacement: step 13, image 1 of 2 Dell Venue 11 Pro Keyboard Port Replacement: step 13, image 2 of 2
    • The final step is to lift the keyboard port free from the frame using your fingers.
2 other people completed this guide.
Tom Nguyen
1,277 Reputation
6 Guides authored
USF Tampa, Team S3-G1, Nance Fall 2017 Member of USF Tampa, Team S3-G1, Nance Fall 2017
USFT-NANCE-F17S3G1
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,701
