Dell Venue 7 Motherboard Replacement
  1. Dell Venue 7 Motherboard Replacement, Rear Case: step 1, image 1 of 2 Dell Venue 7 Motherboard Replacement, Rear Case: step 1, image 2 of 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: step 3, image 1 of 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: step 4, image 1 of 1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: step 5, image 1 of 1
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: step 6, image 1 of 2 Dell Venue 7 Motherboard Replacement, Speaker: step 6, image 2 of 2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: step 7, image 1 of 2 Dell Venue 7 Motherboard Replacement: step 7, image 2 of 2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: step 8, image 1 of 1
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: step 9, image 1 of 2 Dell Venue 7 Motherboard Replacement: step 9, image 2 of 2
    • Gently pull on the wire and remove the speaker.
  10. Dell Venue 7 Motherboard Replacement, Motherboard: step 10, image 1 of 3 Dell Venue 7 Motherboard Replacement, Motherboard: step 10, image 2 of 3 Dell Venue 7 Motherboard Replacement, Motherboard: step 10, image 3 of 3
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: step 11, image 1 of 2 Dell Venue 7 Motherboard Replacement: step 11, image 2 of 2
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: step 12, image 1 of 1
    • Lift and remove the motherboard from the device.
8 other people completed this guide.
Stephen Rousseau
663 Reputation
4 Guides authored
USF Tampa, Team 11-4, Blackwell Winter 2015 Member of USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Members
10 Guides authored
2 Comments
unable to open the lock, can the mother board be changed
Amitabh Mishra - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 4,513
