Dell Venue 7 Speaker Replacement
  1. Dell Venue 7 Speaker Replacement, Rear Case: step 1, image 1 of 2 Dell Venue 7 Speaker Replacement, Rear Case: step 1, image 2 of 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Speaker Replacement, Battery: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Speaker Replacement: step 3, image 1 of 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Speaker Replacement, Speaker: step 4, image 1 of 2 Dell Venue 7 Speaker Replacement, Speaker: step 4, image 2 of 2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  5. Dell Venue 7 Speaker Replacement: step 5, image 1 of 2 Dell Venue 7 Speaker Replacement: step 5, image 2 of 2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  6. Dell Venue 7 Speaker Replacement: step 6, image 1 of 1
    • Remove the plastic covering on the speaker.
  7. Dell Venue 7 Speaker Replacement: step 7, image 1 of 2 Dell Venue 7 Speaker Replacement: step 7, image 2 of 2
    • Gently pull on the wire and remove the speaker.
2 other people completed this guide.
Stephen Rousseau
663 Reputation
4 Guides authored
USF Tampa, Team 11-4, Blackwell Winter 2015 Member of USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 824
