Dell Vostro 1000 Memory Module Replacement
  1. Dell Vostro 1000 Memory Module Replacement, Battery: step 1, image 1 of 1
    • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
  2. Dell Vostro 1000 Memory Module Replacement, Memory Module: step 2, image 1 of 1
    • loosen the captive screws on the memory module cover, and then remove the memory module cover.
  3. Dell Vostro 1000 Memory Module Replacement: step 3, image 1 of 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
2 other people completed this guide.
Johnathan Hammond
45,555 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 281
