Dell Vostro 1220 Hard Drive Replacement
  1. Dell Vostro 1220 Hard Drive Replacement, Remove the battery: step 1, image 1 of 1
    • To remove the battery, unlock the two latches outwards (Orange) and hold them to remove the battery (Red)
  2. Dell Vostro 1220 Hard Drive Replacement, Detach the top bar: step 2, image 1 of 2 Dell Vostro 1220 Hard Drive Replacement, Detach the top bar: step 2, image 2 of 2
    • We're going to have to remove the top bar. To do this, simply unclip the edges carefully (no screws here).
    • The tablecloth is in the middle of the bar. We will remove it after the keyboard so be careful when handling not to tear it off
  3. Dell Vostro 1220 Hard Drive Replacement, Detach the keyboard: step 3, image 1 of 1
    • We have three screws to remove (red) below the bar that we unclipped in step 2 (be careful, the cable is still connected).
    • The keyboard unclips at the top and then removes by sliding upwards (the lower part inserts into the shell directly).
  4. Dell Vostro 1220 Hard Drive Replacement, Unplug the keyboard and the top bar: step 4, image 1 of 1
    • Disconnect the cable from the keyboard and the top bar so that you can remove the assembly and have access below.
  5. Dell Vostro 1220 Hard Drive Replacement, Disconnect the CD player: step 5, image 1 of 2 Dell Vostro 1220 Hard Drive Replacement, Disconnect the CD player: step 5, image 2 of 2
    • To disconnect the CD player, turn the laptop over and remove the only screw that holds it.
    • Once the screw is removed, simply take out the CD player.
  6. Dell Vostro 1220 Hard Drive Replacement, Unplug the WiFi card: step 6, image 1 of 3 Dell Vostro 1220 Hard Drive Replacement, Unplug the WiFi card: step 6, image 2 of 3 Dell Vostro 1220 Hard Drive Replacement, Unplug the WiFi card: step 6, image 3 of 3
    • In order to disconnect the WiFi card, we will open the door by unscrewing two screws and unclipping the cover.
    • We then remove the two connectors from the Wi-Fi card.
    • Finally, we remove the cables from the front of the laptop (the Wi-Fi card is located behind the laptop but the antenna is located in the screen).
  7. Dell Vostro 1220 Hard Drive Replacement, Unplug the screen: step 7, image 1 of 2 Dell Vostro 1220 Hard Drive Replacement, Unplug the screen: step 7, image 2 of 2
    • To disconnect the screen, we will detach the cable and the ground screw.
    • We will also disconnect the tablecloth from the motherboard.
  8. Dell Vostro 1220 Hard Drive Replacement, Remove the last screws from the shell: step 8, image 1 of 1
    • In order to detach the part of the shell below the keyboard, we will remove the last screws behind the laptop.
  9. Dell Vostro 1220 Hard Drive Replacement, Remove the upper part of the shell: step 9, image 1 of 2 Dell Vostro 1220 Hard Drive Replacement, Remove the upper part of the shell: step 9, image 2 of 2
    • The upper part of the shell is removed by sliding down.
    • We will first unclip both sides and the top, then we will slide the shell down
  10. Dell Vostro 1220 Hard Drive Replacement, Detach the hard drive cage: step 10, image 1 of 2 Dell Vostro 1220 Hard Drive Replacement, Detach the hard drive cage: step 10, image 2 of 2
    • We will unscrew the hard drive cage as well as the tablecloth.
    • Then we slide the cage to the right.
To reassemble your device, follow the instructions in reverse order.
Pay attention to the alignment of the Wi-Fi button on the motherboard (at the bottom of the laptop) with that of the laptop shell when reassembly.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
the_red_mage
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 16
All Time: 479
