Dell Vostro 1320 USB Port Replacement
  1. Dell Vostro 1320 USB Port Replacement, USB Port: step 1, image 1 of 1
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: step 2, image 1 of 1
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: step 3, image 1 of 3 Dell Vostro 1320 USB Port Replacement: step 3, image 2 of 3 Dell Vostro 1320 USB Port Replacement: step 3, image 3 of 3
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: step 4, image 1 of 1
  5. Dell Vostro 1320 USB Port Replacement: step 5, image 1 of 3 Dell Vostro 1320 USB Port Replacement: step 5, image 2 of 3 Dell Vostro 1320 USB Port Replacement: step 5, image 3 of 3
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: step 6, image 1 of 1
  7. Dell Vostro 1320 USB Port Replacement: step 7, image 1 of 2 Dell Vostro 1320 USB Port Replacement: step 7, image 2 of 2
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: step 8, image 1 of 1
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: step 9, image 1 of 2 Dell Vostro 1320 USB Port Replacement: step 9, image 2 of 2
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: step 10, image 1 of 3 Dell Vostro 1320 USB Port Replacement: step 10, image 2 of 3 Dell Vostro 1320 USB Port Replacement: step 10, image 3 of 3
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: step 11, image 1 of 1
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: step 12, image 1 of 1
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: step 13, image 1 of 2 Dell Vostro 1320 USB Port Replacement: step 13, image 2 of 2
    • Gently lift out the USB port.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 647
