Dell Vostro 15 3562 Hard Drive Replacement
  1. Dell Vostro 15 3562 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3562 Hard Drive Replacement, Optical-Disk Drive: step 2, image 1 of 1
    • Remove the M2L3 screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3562 Hard Drive Replacement, KeyBoard: step 3, image 1 of 1
    • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
    • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
  4. Dell Vostro 15 3562 Hard Drive Replacement: step 4, image 1 of 1
    • Disconnect the keyboard cable from the system board.
    • Remove the keyboard from the computer.
  5. Dell Vostro 15 3562 Hard Drive Replacement, Base Cover: step 5, image 1 of 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the M2L5 screws that secure the base cover [2].
  6. Dell Vostro 15 3562 Hard Drive Replacement: step 6, image 1 of 1
    • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
  7. Dell Vostro 15 3562 Hard Drive Replacement: step 7, image 1 of 1
    • Use a scribe to pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Dell Vostro 15 3562 Hard Drive Replacement, Hard Drive: step 8, image 1 of 1
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the M2L3 screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
Johnathan Hammond
45,237 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 365
