Dell Vostro 15 KeyBoard Replacement
  1. Dell Vostro 15 KeyBoard Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 15 KeyBoard Replacement, Hinge Cover: step 2, image 1 of 1
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
  3. Dell Vostro 15 KeyBoard Replacement, KeyBoard: step 3, image 1 of 1
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
Johnathan Hammond
45,210 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 13
All Time: 516
