Dell Vostro 1500 Keyboard Replacement
  1. Dell Vostro 1500 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: step 2, image 1 of 1
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: step 3, image 1 of 1
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: step 4, image 1 of 1
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: step 5, image 3 of 3
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: step 6, image 1 of 2 Dell Vostro 1500 Keyboard Replacement: step 6, image 2 of 2
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: step 7, image 1 of 2 Dell Vostro 1500 Keyboard Replacement: step 7, image 2 of 2
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: step 8, image 1 of 3 Dell Vostro 1500 Keyboard Replacement: step 8, image 2 of 3 Dell Vostro 1500 Keyboard Replacement: step 8, image 3 of 3
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: step 9, image 1 of 1
    • Pull the connector toward the screen.
2 other people completed this guide.
Daniel Roskuski
219 Reputation
2 Guides authored
UMass Dartmouth, Team 1-3, Catania Fall 2016 Member of UMass Dartmouth, Team 1-3, Catania Fall 2016
UMASSD-CATANIA-F16S1G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 974
