Dell Vostro 1510 Memory Module Replacement
  1. Dell Vostro 1510 Memory Module Replacement, Battery: step 1, image 1 of 1
    • Slide the battery lock to the open position.{2}
    • Slide the battery release latch to the open position. (You may need to hold the battery release latch in the open position while removing the battery.) {3}
    • Slide the battery out of the battery bay.{1}
  2. Dell Vostro 1510 Memory Module Replacement, Memory Module: step 2, image 1 of 1
    • Remove the two screws that secure the memory cover, then remove the cover and set it aside.
  3. Dell Vostro 1510 Memory Module Replacement: step 3, image 1 of 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Johnathan Hammond
45,555 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 253
