Dell Vostro 1700 Memory Module Replacement
  1. Dell Vostro 1700 Memory Module Replacement, Removing the Battery: step 1, image 1 of 1
    • Slide and click the battery release latches to keep them open.
    • Slide the battery out of the bay.
  2. Dell Vostro 1700 Memory Module Replacement, Removing the Hinge Cover: step 2, image 1 of 1
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Ease the hinge cover up, moving from right to left, and remove it.
  3. Dell Vostro 1700 Memory Module Replacement, Removing the Keyboard: step 3, image 1 of 1
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
    • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
    • Lift and remove the keyboard.
  4. Dell Vostro 1700 Memory Module Replacement, Removing the Memory Module: step 4, image 1 of 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the memory module from the connector.
Finish Line
Johnathan Hammond
45,034 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 178
