Dell Vostro 1700 RAM Replacement
  1. Dell Vostro 1700 RAM Replacement, Keyboard: step 1, image 1 of 3 Dell Vostro 1700 RAM Replacement, Keyboard: step 1, image 2 of 3 Dell Vostro 1700 RAM Replacement, Keyboard: step 1, image 3 of 3
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: step 2, image 1 of 1
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: step 3, image 1 of 2 Dell Vostro 1700 RAM Replacement: step 3, image 2 of 2
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: step 4, image 1 of 2 Dell Vostro 1700 RAM Replacement: step 4, image 2 of 2
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: step 5, image 1 of 2 Dell Vostro 1700 RAM Replacement: step 5, image 2 of 2
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: step 6, image 1 of 3 Dell Vostro 1700 RAM Replacement, RAM: step 6, image 2 of 3 Dell Vostro 1700 RAM Replacement, RAM: step 6, image 3 of 3
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: step 7, image 1 of 3 Dell Vostro 1700 RAM Replacement: step 7, image 2 of 3 Dell Vostro 1700 RAM Replacement: step 7, image 3 of 3
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: step 8, image 1 of 3 Dell Vostro 1700 RAM Replacement: step 8, image 2 of 3 Dell Vostro 1700 RAM Replacement: step 8, image 3 of 3
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: step 9, image 1 of 2 Dell Vostro 1700 RAM Replacement: step 9, image 2 of 2
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: step 10, image 1 of 3 Dell Vostro 1700 RAM Replacement: step 10, image 2 of 3 Dell Vostro 1700 RAM Replacement: step 10, image 3 of 3
    • Lift the RAM chip up and out of the slot.
2 other people completed this guide.
Nathan Valm
735 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,043
