Dell Vostro 1710 Hard Drive Replacement
  1. Dell Vostro 1710 Hard Drive Replacement, Removing the Battery: step 1, image 1 of 1
    • Slide both battery latches to the open position.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 1710 Hard Drive Replacement, Loosen the Screws: step 2, image 1 of 1
    • Loosen the five screws that secure the hard-drive compartment cover.
    • Remove the cover and set it aside.
  3. Dell Vostro 1710 Hard Drive Replacement, Removing the Hard Drive Cable: step 3, image 1 of 1
    • Remove the three screws that secure the hard drive to the computer.
    • One screw is attached to a metal tab on the metal base of the hard drive, and the other two screws are attached to the metal base.
    • Disconnect the hard drive cable connector from the motherboard.
    • Pull the mylar tab to release the hard drive.
    • Lift the hard drive and the hard drive cable out of the computer. You may find it easier to lift the hard drive starting from the side located opposite from the hard drive's connection to the hard drive cable.
Finish Line
Johnathan Hammond
45,034 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 626
