Dell Vostro 1710 Hard Drive Replacement
  1. Dell Vostro 1710 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Hard Drive Replacement: step 2, image 1 of 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Dell Vostro 1710 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Remove the following five Phillips #1 6mm screws.
  5. Dell Vostro 1710 Hard Drive Replacement: step 5, image 1 of 1
    • Lift back cover from the groove on the right side of the cover next to the symbol.
  6. Dell Vostro 1710 Hard Drive Replacement: step 6, image 1 of 2 Dell Vostro 1710 Hard Drive Replacement: step 6, image 2 of 2
    • Pull up on the blue tab that is attached to the ribbon cable to unplug it.
  7. Dell Vostro 1710 Hard Drive Replacement: step 7, image 1 of 2 Dell Vostro 1710 Hard Drive Replacement: step 7, image 2 of 2
    • Remove the three Philips #1 3mm screws.
  8. Dell Vostro 1710 Hard Drive Replacement: step 8, image 1 of 2 Dell Vostro 1710 Hard Drive Replacement: step 8, image 2 of 2
    • Lift and remove the Hard Drive frame by pulling up on the blue tab.
  9. Dell Vostro 1710 Hard Drive Replacement: step 9, image 1 of 2 Dell Vostro 1710 Hard Drive Replacement: step 9, image 2 of 2
    • Remove the two 3mm screws with a Philips #1 screwdriver from the back side of the frame to remove the Hard drive.
Jeremy Campeau
347 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 869
