Dell Vostro 1710 Heatsink Replacement
  1. Dell Vostro 1710 Heatsink Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 Heatsink Replacement, Battery: step 1, image 2 of 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: step 2, image 1 of 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: step 3, image 1 of 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: step 4, image 1 of 2 Dell Vostro 1710 Heatsink Replacement, Back Panel: step 4, image 2 of 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: step 5, image 1 of 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: step 6, image 1 of 2 Dell Vostro 1710 Heatsink Replacement, Fan: step 6, image 2 of 2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: step 7, image 1 of 2 Dell Vostro 1710 Heatsink Replacement: step 7, image 2 of 2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: step 8, image 1 of 2 Dell Vostro 1710 Heatsink Replacement: step 8, image 2 of 2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: step 9, image 1 of 2 Dell Vostro 1710 Heatsink Replacement, Heatsink: step 9, image 2 of 2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: step 10, image 1 of 2 Dell Vostro 1710 Heatsink Replacement: step 10, image 2 of 2
    • Lift up on the heatsink to remove it from the laptop.
Tangxiao Sun
496 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 285
