Dell Vostro 1710 Keyboard Replacement
  1. Dell Vostro 1710 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Keyboard Replacement: step 2, image 1 of 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Keyboard Replacement: step 3, image 1 of 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
  5. Dell Vostro 1710 Keyboard Replacement: step 5, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 5, image 2 of 2
    • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
  6. Dell Vostro 1710 Keyboard Replacement: step 6, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 6, image 2 of 2
    • Remove the four 3mm Philips #1 head screws.
  7. Dell Vostro 1710 Keyboard Replacement: step 7, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 7, image 2 of 2
    • Gently lift up the keyboard to remove.
    • Flip it over as it shown in the picture.
  8. Dell Vostro 1710 Keyboard Replacement: step 8, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 8, image 2 of 2
    • Lift the black tab that the keyboard is plugged into.
  9. Dell Vostro 1710 Keyboard Replacement: step 9, image 1 of 2 Dell Vostro 1710 Keyboard Replacement: step 9, image 2 of 2
    • Pull directly outwards to remove the keyboard completely.
Tangxiao Sun
496 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 685
