Dell Vostro 1710 RAM Replacement
  1. Dell Vostro 1710 RAM Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 RAM Replacement, Battery: step 1, image 2 of 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 RAM Replacement: step 2, image 1 of 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 RAM Replacement: step 3, image 1 of 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 RAM Replacement, Back Panel: step 4, image 1 of 2 Dell Vostro 1710 RAM Replacement, Back Panel: step 4, image 2 of 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 RAM Replacement: step 5, image 1 of 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 RAM Replacement, RAM: step 6, image 1 of 2 Dell Vostro 1710 RAM Replacement, RAM: step 6, image 2 of 2
    • Push the metal tabs outward and away from the RAM.
  7. Dell Vostro 1710 RAM Replacement: step 7, image 1 of 2 Dell Vostro 1710 RAM Replacement: step 7, image 2 of 2
    • Pull the top piece straight out of the socket.
  8. Dell Vostro 1710 RAM Replacement: step 8, image 1 of 2 Dell Vostro 1710 RAM Replacement: step 8, image 2 of 2
    • Repeat the same process by pushing the bottom metal tabs outward and away from the RAM.
  9. Dell Vostro 1710 RAM Replacement: step 9, image 1 of 2 Dell Vostro 1710 RAM Replacement: step 9, image 2 of 2
    • Pull the bottom piece straight out of the socket.
Sarah Dulac
270 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 645
