Dell Vostro 1710 Wi-Fi Card Replacement
  1. Dell Vostro 1710 Wi-Fi Card Replacement, Battery: step 1, image 1 of 2 Dell Vostro 1710 Wi-Fi Card Replacement, Battery: step 1, image 2 of 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Wi-Fi Card Replacement, Back Panel: step 4, image 1 of 2 Dell Vostro 1710 Wi-Fi Card Replacement, Back Panel: step 4, image 2 of 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Wi-Fi Card Replacement: step 5, image 1 of 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 1 of 2 Dell Vostro 1710 Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 2 of 2
    • Remove the two 3mm Philips #1 screws from the top of the Wi-Fi card.
  7. Dell Vostro 1710 Wi-Fi Card Replacement: step 7, image 1 of 2 Dell Vostro 1710 Wi-Fi Card Replacement: step 7, image 2 of 2
    • Unclip both black and white wires from the Wi-Fi card.
  8. Dell Vostro 1710 Wi-Fi Card Replacement: step 8, image 1 of 1
    • Gently pull Wi-Fi card out of its position at its angle.
Jeremy Campeau
347 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 387
