Dell Vostro 3360 Hard Drive Replacement
Johnathan Hammond
Johnathan Hammond and one other contributor
Last updated on November 9, 2019
20 - 40 minutes
Moderate
Community-Contributed Guide
Tools
  1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: step 1, image 1 of 1
    • Remove the screw that secures the keyboard to the chassis.
  2. Dell Vostro 3360 Hard Drive Replacement, Prying the Keyboard: step 2, image 1 of 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  3. Dell Vostro 3360 Hard Drive Replacement, Flipping the Keyboard: step 3, image 1 of 1
    • Flip the keyboard over and lay it on the palmrest.
  4. Dell Vostro 3360 Hard Drive Replacement, Lifting the Clip: step 4, image 1 of 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  5. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: step 5, image 1 of 1
    • Remove the screw that secures the access panel to the computer.
  6. Dell Vostro 3360 Hard Drive Replacement, Remove the Access Panel: step 6, image 1 of 1
    • Remove the access panel from the computer.
  7. Dell Vostro 3360 Hard Drive Replacement, Display-Hinge Cover: step 7, image 1 of 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Hard Drive Replacement, Remove the Display Hinge Cover: step 8, image 1 of 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Hard Drive Replacement, Prying the Rubber Pads: step 9, image 1 of 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: step 10, image 1 of 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the Board Cable: step 11, image 1 of 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the LED Cable: step 12, image 1 of 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: step 13, image 1 of 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Hard Drive Replacement, Prying the Edges of the Palm-Rest: step 14, image 1 of 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Hard Drive Replacement, Lifting the Palm Rest: step 15, image 1 of 1
    • Lift the palm-rest up and away from the computer.
  16. Dell Vostro 3360 Hard Drive Replacement, Hard Drive: step 16, image 1 of 1
    • Remove the screws that secure the hard drive to the computer.
  17. Dell Vostro 3360 Hard Drive Replacement: step 17, image 1 of 1
    • Lift the hard drive to disconnect the hard-drive cable
  18. Dell Vostro 3360 Hard Drive Replacement: step 18, image 1 of 1
    • Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
  19. Dell Vostro 3360 Hard Drive Replacement: step 19, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
4 other people completed this guide.
Johnathan Hammond
45,210 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 3,351
