Dell Vostro 3360 Palm-Rest Replacement
  1. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: step 1, image 1 of 1
    • Remove the screw that secures the access panel to the computer.
  2. Dell Vostro 3360 Palm-Rest Replacement, Remove the Access Panel: step 2, image 1 of 1
    • Remove the access panel from the computer.
  3. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screw: step 3, image 1 of 1
    • Remove the screw that secures the keyboard to the chassis.
  4. Dell Vostro 3360 Palm-Rest Replacement, Prying the Keyboard: step 4, image 1 of 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  5. Dell Vostro 3360 Palm-Rest Replacement, Flipping the Keyboard: step 5, image 1 of 1
    • Flip the keyboard over and lay it on the palmrest.
  6. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Clip: step 6, image 1 of 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  7. Dell Vostro 3360 Palm-Rest Replacement, Display-Hinge Cover: step 7, image 1 of 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Palm-Rest Replacement, Remove the Display Hinge Cover: step 8, image 1 of 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Palm-Rest Replacement, Prying the Rubber Pads: step 9, image 1 of 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: step 10, image 1 of 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the Board Cable: step 11, image 1 of 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Palm-Rest Replacement, Disconnecting the LED Cable: step 12, image 1 of 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Palm-Rest Replacement, Remove the Screws: step 13, image 1 of 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Palm-Rest Replacement, Prying the Edges of the Palm-Rest: step 14, image 1 of 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Palm-Rest Replacement, Lifting the Palm Rest: step 15, image 1 of 1
    • Lift the palm-rest up and away from the computer.
Finish Line
Johnathan Hammond
45,034 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 218
