Dell Vostro 3550 Disk Drive Tray Latch Replacement
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: step 1, image 1 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: step 1, image 2 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: step 1, image 3 of 3
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 2, image 1 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 2, image 2 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 2, image 3 of 3
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 3, image 1 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 3, image 2 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 3, image 3 of 3
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 4, image 1 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 4, image 2 of 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: step 4, image 3 of 3
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Dylan J. Souza
781 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 266
