Dell Vostro 3550 RAM Replacement
  1. Dell Vostro 3550 RAM Replacement, Unlocking the Battery: step 1, image 1 of 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 3550 RAM Replacement, Sliding the Battery: step 2, image 1 of 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3550 RAM Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
  4. Dell Vostro 3550 RAM Replacement, Lifting the Access Panel: step 4, image 1 of 1
    • Lift the access panel up at an angle and remove it from the computer.
  5. Dell Vostro 3550 RAM Replacement, RAM: step 5, image 1 of 3 Dell Vostro 3550 RAM Replacement, RAM: step 5, image 2 of 3 Dell Vostro 3550 RAM Replacement, RAM: step 5, image 3 of 3
    • Push outward on the two release tabs securing either side of the top RAM module.
  6. Dell Vostro 3550 RAM Replacement: step 6, image 1 of 3 Dell Vostro 3550 RAM Replacement: step 6, image 2 of 3 Dell Vostro 3550 RAM Replacement: step 6, image 3 of 3
    • Lift the top stick of RAM upward away from the motherboard.
  7. Dell Vostro 3550 RAM Replacement: step 7, image 1 of 2 Dell Vostro 3550 RAM Replacement: step 7, image 2 of 2
    • Push outward on the two release tabs securing either side of the second RAM module.
  8. Dell Vostro 3550 RAM Replacement: step 8, image 1 of 3 Dell Vostro 3550 RAM Replacement: step 8, image 2 of 3 Dell Vostro 3550 RAM Replacement: step 8, image 3 of 3
    • Lift the stick of RAM upward away from the motherboard.
Nickolas LaForce
178 Reputation
1 Guide authored
1 Guide Comment
Hi
Thanks for the tutorial.
High standard.
Keep it up
Regards
Lourens
Lourens - Reply Share
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 26
All Time: 772
