Dell Vostro 3560 RAM Replacement
  1. Dell Vostro 3560 RAM Replacement, Identify your laptop: step 1, image 1 of 2 Dell Vostro 3560 RAM Replacement, Identify your laptop: step 1, image 2 of 2
    • Make sure you have the right laptop by checking the sticker.
  2. Dell Vostro 3560 RAM Replacement, Remove Battery: step 2, image 1 of 2 Dell Vostro 3560 RAM Replacement, Remove Battery: step 2, image 2 of 2
    • Start with your PC shut off and upside down.
    • Pull out tabs.
    • Pull up on rail to remove battery.
  3. Dell Vostro 3560 RAM Replacement, Remove Back Panel: step 3, image 1 of 1
    • Remove the two screws:
    • One M2 Phillips screw (Fixed)
    • One 5-mm M2 Phillips screw
  4. Dell Vostro 3560 RAM Replacement: step 4, image 1 of 3 Dell Vostro 3560 RAM Replacement: step 4, image 2 of 3 Dell Vostro 3560 RAM Replacement: step 4, image 3 of 3
    • Use a iFixit opening tool to remove the back panel.
  5. Dell Vostro 3560 RAM Replacement: step 5, image 1 of 1
    • From here you can access:
    • The hard drive
    • The RAM.
    • The CD Drive.
  6. Dell Vostro 3560 RAM Replacement, RAM Removal: step 6, image 1 of 1
    • We will focus on the RAM.
  7. Dell Vostro 3560 RAM Replacement: step 7, image 1 of 3 Dell Vostro 3560 RAM Replacement: step 7, image 2 of 3 Dell Vostro 3560 RAM Replacement: step 7, image 3 of 3
    • Pull out on the tabs to release RAM.
    • Pull out the RAM.
    • If you have two SoDIMMs installed, start with the top one and repeat the proccess for the lower one.
    • When reinstalling ram, make sure it is fully inserted before fully locking it down.
Max Bareilles
703 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 856
