Dell Vostro 3750 Hard Drive Replacement
  1. Dell Vostro 3750 Hard Drive Replacement, Unlocking the Battery: step 1, image 1 of 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 3750 Hard Drive Replacement, Removing the Battery: step 2, image 1 of 1
    • Slide the battery out of the chassis and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3750 Hard Drive Replacement, Loosen the Screws: step 3, image 1 of 1
    • Loosen the screws that secure the memory door.
  4. Dell Vostro 3750 Hard Drive Replacement, Removing the Memory Door: step 4, image 1 of 1
    • Pry up the memory door near the screw hole, lift, and remove it
  5. Dell Vostro 3750 Hard Drive Replacement, Remove the Screws: step 5, image 1 of 1
    • Remove the screws that secure the hard-drive bracket.
  6. Dell Vostro 3750 Hard Drive Replacement, Sliding the Module: step 6, image 1 of 1
    • Slide the hard drive module in the direction shown in the image below.
  7. Dell Vostro 3750 Hard Drive Replacement, Remove the Hard Drive Module: step 7, image 1 of 1
    • Remove the hard drive module from the system board.
  8. Dell Vostro 3750 Hard Drive Replacement, Remove the Screws: step 8, image 1 of 1
  9. Dell Vostro 3750 Hard Drive Replacement, Sliding the Hard Drive: step 9, image 1 of 1
    • Slide the hard drive from the hard-drive bracket.
Finish Line
2 other people completed this guide.
Johnathan Hammond
45,058 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
One Comment
thanks for that info ! ! ! :-)
Marquis McCheever - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,647
