Dell Vostro 3750 Memory Module Replacement
  1. Dell Vostro 3750 Memory Module Replacement, Unlocking the Battery: step 1, image 1 of 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 3750 Memory Module Replacement, Removing the Battery: step 2, image 1 of 1
    • Slide the battery out of the chassis and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3750 Memory Module Replacement, Loosen the Screws: step 3, image 1 of 1
    • Loosen the screws that secure the memory door.
  4. Dell Vostro 3750 Memory Module Replacement, Removing the Memory Door: step 4, image 1 of 1
    • Pry up the memory door near the screw hole, lift, and remove it
  5. Dell Vostro 3750 Memory Module Replacement, Popping up the Memory Module: step 5, image 1 of 1
    • Pry the retention clips away from the memory module until it pops up.
  6. Dell Vostro 3750 Memory Module Replacement, Removing the Memory Module: step 6, image 1 of 1
    • Remove the memory module from its connector on the system board.
Johnathan Hammond
45,210 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 286
