Dell Vostro 5459 Memory Module Replacement
  1. Dell Vostro 5459 Memory Module Replacement, Removing the Base Cover: step 1, image 1 of 1
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Memory Module Replacement, Removing the Battery: step 2, image 1 of 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Memory Module Replacement, Removing the Memory Module: step 3, image 1 of 1
    • Lift the plastic enclosure covering the top of the memory module compartment.
    • Pull the retention clips from the memory module until it pops up.
    • Remove the memory module from the connector on the system board.
Johnathan Hammond
45,555 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 330
