Dell Vostro 5510 Back Cover Replacement
Ky Vang
Ky Vang and one other contributor
Last updated on January 25, 2024
3 minutes
Easy
Introduction
Go to step 1
The first step in any replacement of the internal components of the Dell Vostro 15 5510 is to remove its back cover. To complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. This guide also is necessary for accessing most of the internal components of the laptop.
Tools
  1. Dell Vostro 5510 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Back Cover Replacement: step 2, image 1 of 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Back Cover Replacement: step 3, image 1 of 3 Dell Vostro 5510 Back Cover Replacement: step 3, image 2 of 3 Dell Vostro 5510 Back Cover Replacement: step 3, image 3 of 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Back Cover Replacement: step 4, image 1 of 3 Dell Vostro 5510 Back Cover Replacement: step 4, image 2 of 3 Dell Vostro 5510 Back Cover Replacement: step 4, image 3 of 3
    • Lift the cover to remove it from the rest of the laptop.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 385
