Dell Vostro 5510 Fan Replacement
  1. Dell Vostro 5510 Fan Replacement, Back Cover: step 1, image 1 of 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Fan Replacement: step 2, image 1 of 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Fan Replacement: step 3, image 1 of 3 Dell Vostro 5510 Fan Replacement: step 3, image 2 of 3 Dell Vostro 5510 Fan Replacement: step 3, image 3 of 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Fan Replacement: step 4, image 1 of 3 Dell Vostro 5510 Fan Replacement: step 4, image 2 of 3 Dell Vostro 5510 Fan Replacement: step 4, image 3 of 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Fan Replacement, Fan: step 5, image 1 of 3 Dell Vostro 5510 Fan Replacement, Fan: step 5, image 2 of 3 Dell Vostro 5510 Fan Replacement, Fan: step 5, image 3 of 3
    • Disconnect the fan cable from the system board.
  6. Dell Vostro 5510 Fan Replacement: step 6, image 1 of 3 Dell Vostro 5510 Fan Replacement: step 6, image 2 of 3 Dell Vostro 5510 Fan Replacement: step 6, image 3 of 3
    • Remove the two (M2x3mm) screws from the fan using the screwdriver.
  7. Dell Vostro 5510 Fan Replacement: step 7, image 1 of 2 Dell Vostro 5510 Fan Replacement: step 7, image 2 of 2
    • Lift the fan to remove it.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 198
