Dell Vostro 5510 Touchpad Replacement
  1. Dell Vostro 5510 Touchpad Replacement, Back Cover: step 1, image 1 of 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Touchpad Replacement: step 2, image 1 of 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Touchpad Replacement: step 3, image 1 of 3 Dell Vostro 5510 Touchpad Replacement: step 3, image 2 of 3 Dell Vostro 5510 Touchpad Replacement: step 3, image 3 of 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Touchpad Replacement: step 4, image 1 of 3 Dell Vostro 5510 Touchpad Replacement: step 4, image 2 of 3 Dell Vostro 5510 Touchpad Replacement: step 4, image 3 of 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Touchpad Replacement, Battery: step 5, image 1 of 1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Touchpad Replacement: step 6, image 1 of 3 Dell Vostro 5510 Touchpad Replacement: step 6, image 2 of 3 Dell Vostro 5510 Touchpad Replacement: step 6, image 3 of 3
    • Lift the battery to remove it
  7. Dell Vostro 5510 Touchpad Replacement, Touchpad: step 7, image 1 of 3 Dell Vostro 5510 Touchpad Replacement, Touchpad: step 7, image 2 of 3 Dell Vostro 5510 Touchpad Replacement, Touchpad: step 7, image 3 of 3
    • Disconnect the touchpad from the motherboard using a pair of tweezers.
    • Use a gentle and slow outward movement to minimize the risk of breaking the connection.
  8. Dell Vostro 5510 Touchpad Replacement: step 8, image 1 of 2 Dell Vostro 5510 Touchpad Replacement: step 8, image 2 of 2
    • Remove the three 2.2mm screws holding the guard bar in place with the Phillips #0 screwdriver.
  9. Dell Vostro 5510 Touchpad Replacement: step 9, image 1 of 1
    • Remove the guard bar using a pair of tweezers.
  10. Dell Vostro 5510 Touchpad Replacement: step 10, image 1 of 2 Dell Vostro 5510 Touchpad Replacement: step 10, image 2 of 2
    • Unscrew the two 7 mm base head screws from the touchpad with the Phillips #0 screwdriver.
  11. Dell Vostro 5510 Touchpad Replacement: step 11, image 1 of 1
    • Remove the touchpad from the computer by lifting the side closest to the edge and pulling out.
Emanuel
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 119
