Dell Vostro 5560 Hard Drive Replacement
  1. Dell Vostro 5560 Hard Drive Replacement, Removing The Optical-Disk Drive: step 1, image 1 of 1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: step 2, image 1 of 2 Dell Vostro 5560 Hard Drive Replacement, Replacing the Base Cover: step 2, image 2 of 2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Hard Drive Replacement, Removing the Battery: step 3, image 1 of 1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive: step 4, image 1 of 1
    • Ease the I/O cable from the routing tabs.
    • Disconnect the hard-drive cable from the system board and remove the screws that secures the hard-drive in place
    • Lift and remove the hard-drive from the computer
  5. Dell Vostro 5560 Hard Drive Replacement, Disconnecting the Hard Drive Connector: step 5, image 1 of 1
    • Disconnect the hard-drive connector from hard drive.
  6. Dell Vostro 5560 Hard Drive Replacement, Remove the Screws: step 6, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
Finish Line
2 other people completed this guide.
Johnathan Hammond
45,058 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 226
