Dell Vostro A840 Memory Module Replacement
  1. Dell Vostro A840 Memory Module Replacement, Remove the battery: step 1, image 1 of 1
    • Unlock the battery by sliding the battery-lock latch towards the outer edge.
    • Slide the battery-bay release latch and hold it.
    • Remove the battery from the battery bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro A840 Memory Module Replacement, Remove the Module Cover: step 2, image 1 of 1
    • Remove the two screws from the module cover.
    • Lift the module cover away from the computer.
  3. Dell Vostro A840 Memory Module Replacement, Removing the Memory Module: step 3, image 1 of 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Johnathan Hammond
45,555 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 104
