Dell Vostro V13 Back Cover and Battery Removal
  1. Dell Vostro V13  Back Cover and Battery Removal, Back Cover: step 1, image 1 of 3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: step 1, image 2 of 3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: step 1, image 3 of 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13  Back Cover and Battery Removal: step 2, image 1 of 3 Dell Vostro V13  Back Cover and Battery Removal: step 2, image 2 of 3 Dell Vostro V13  Back Cover and Battery Removal: step 2, image 3 of 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13  Back Cover and Battery Removal: step 3, image 1 of 3 Dell Vostro V13  Back Cover and Battery Removal: step 3, image 2 of 3 Dell Vostro V13  Back Cover and Battery Removal: step 3, image 3 of 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13  Back Cover and Battery Removal: step 4, image 1 of 2 Dell Vostro V13  Back Cover and Battery Removal: step 4, image 2 of 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13  Back Cover and Battery Removal: step 5, image 1 of 3 Dell Vostro V13  Back Cover and Battery Removal: step 5, image 2 of 3 Dell Vostro V13  Back Cover and Battery Removal: step 5, image 3 of 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13  Back Cover and Battery Removal: step 6, image 1 of 2 Dell Vostro V13  Back Cover and Battery Removal: step 6, image 2 of 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 387
