Dell Vostro V130 Memory Module Replacement
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: step 1, image 1 of 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: step 2, image 1 of 1
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: step 3, image 1 of 1
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: step 4, image 1 of 1
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: step 5, image 1 of 1
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: step 6, image 1 of 1
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: step 7, image 1 of 1
    • Pull the LED cover toward the keyboard and remove it from the computer.
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: step 8, image 1 of 1
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  9. Dell Vostro V130 Memory Module Replacement: step 9, image 1 of 1
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
Finish Line
Johnathan Hammond
45,555 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 439
