Dell Wyse Xn0m Fan Replacement
  1. Dell Wyse Xn0m Fan Replacement, Fan: step 1, image 1 of 3 Dell Wyse Xn0m Fan Replacement, Fan: step 1, image 2 of 3 Dell Wyse Xn0m Fan Replacement, Fan: step 1, image 3 of 3
    • Use a spudger to unclip the keyboard from the main body by disengaging the clips lined around the top and sides of the keyboard.
    • Once lifted, push the white slider holding blue ribbon cable and put keyboard to the side.
  2. Dell Wyse Xn0m Fan Replacement: step 2, image 1 of 1
    • With the spudger, remove sliders that are holding the purple ribbon cable.
    • Disconnect cable by the power button.
  3. Dell Wyse Xn0m Fan Replacement: step 3, image 1 of 1
    • Remove the five 7mm Phillips #1 screws underneath the keyboard.
  4. Dell Wyse Xn0m Fan Replacement: step 4, image 1 of 1
    • Close the laptop and flip it over.
    • Remove eight 7mm Phillips #1 screws along the edges of laptop.
    • Put these screws to the side (make sure to keep them apart from keyboard screws).
  5. Dell Wyse Xn0m Fan Replacement: step 5, image 1 of 1
    • After removing the screws, flip the laptop back over and open the screen.
    • Lift the laptop's keyboard/mouse pad top with an opening tool.
  6. Dell Wyse Xn0m Fan Replacement: step 6, image 1 of 2 Dell Wyse Xn0m Fan Replacement: step 6, image 2 of 2
    • Unplug the cable connecting the fan to the motherboard.
    • Lift the tape holding down the cables over the fan.
    • Undo two 5mm Phillips #1 screws.
    • The top left screw is covered by the cables. Use a spudger to get it out of the way.
    • Lift the fan out of its slot.
The process is simple but tedious. Be patient, keep the screws organized, be gentle with the clips and you are good to go!
2 other people completed this guide.
Daniel Hill
175 Reputation
1 Guide authored
One Comment
excelent work. thanks for share
Asimple Guy - Reply
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 56
All Time: 1,150
